2008 X6 4.4 V8 Check Engine Indicator Light Lits
cegeng
While accelerating, the engine suddenly vibrates and check engine inidicator light lits. On the driver's monitor, it read as " LESS POWER. DRIVE SLOWLY. Maximum to cruize is anly at 80-90 km/h. Sent the car to BMW's mechanic to diagnose and it read as 1. LAMBDA SENSOR 2. LOW FUEL PRESSURE,CYLINDER No. 3.
Replaced the sensor and once again had the car diagnosed; and still the same reading appeared on the diagnostic module. Have any member countered the same problem before?
Houston
Hey, my friend has faced the same problem which you have discussed here...
He says to me, an engine misfire could be one of the reasons. Sometimes an engine misfire causes an increase in hydrocarbon emissions, which is one of the reasons for "check the engine light" on. Moreover, when the check engine light turns on and the car is shaking, that means you're facing an engine misfire issue in your vehicle. If my answer seems useful and you want to know more about sudden engine malfunction, look here-https://www.usedengines.us/blog.php. You will find useful answers to multiple queries.
