Hi- Just noticed yesterday the carpet and floormat on only the driver's side of my E39 is wet. It is water, not antifreeze. Also, I've been seeing water drip from the driver's side rocker panel. I've been using the A/C (it's on all the time): could the drain for the a/c sysytem be clogged? Where is the drain tube under the car?
Thanks in advance for the help!!!!
