hot bimmer!!
70
Nutley
Hi,
I own 2001 530i and recently I have noticed that my temperature gage is going awfully close to red zone. It even went over to red zone so I sopped the car and shut off the engine to let it cool off.
Checked the antifreeze level, it is OK. Now when I drive it seems to be very sporadic, when it gets too close to red I just turn on the heat and it goes back to the middle of the gage like it should, and it stays there as long and heat is on.
What do you guys think that might be?
Any advice would be appreciated
First off make sure the system has been purged of air. There is a bleeder screw in the system for this. Every BMW I have owned has run dead center if not a little to the cold side. IF your getting to the red you need to stop driving her and get the problem resolved. If not bleeding the system, check the fan clutch. thermostat, and water pump.
70
Nutley
my fan clutch was replaced 4 months ago, the water pump works because heat works.
I just have to check for air in the system and thermostat. Hope this will fix the problem
