What I thought would be a simple upgrade, has turned into something of a Crusade. The sound in my 2000 540i was not sufficient enough. So I led myself to believe that I could take the amp and sub from my previous car '99 SVT Contour (MTX Audio 5-Channel 800W & 10in box) and have a quick remedy to my problem. The sound from this setup (w/ 3-way Pioneers in the doors and back with a Blaukpunt unit) was awesome!! So one would think a simple swap would be a "Good" thing...WRONG!! After my favorite shop spent nearly 10 hours working on my car, the sound is actually worse than before!
I was given the MA Audio Y3K5C 5.25in 250w component system as a gift, which I figured had to be an improvement over the factory. With a more powerful amp and a big sub...where could I go wrong??
Here's the current setup on the new MTX 5 Channel Amp...Keeping the OEM BMW head unit, I have the front doors (5 1/4 and 2 components each) occupy the first 2 channels, the rears (5 1/4s rear window and 1 component in doors) take another 2 channels, and the sub box in the trunk take the 5th channel. This was a nightmare for the installer, as he had to disconnect every component connection from the original OEM amp and re-route everything to the new amp. I was surprised to find out that I had two tiny little subs hidden above the trunk! Surprised, because I have never been happy with the level of bass the OEM setup produced. These subs are still being run by the OEM amp. The OEM speakers were a killer to get out of the car, as they had to literally remove my entire back seat. I was nearly in tears. So, 10 hours later I had a banging new sound system right??? WRONG AGAIN!! It sounds "Ugly".
My installer is confident the outputs are all correct, but before blaming the speakers, he's going to test the polarity of the inputs (??), but suggested not buying new speakers before he tested it later this week. Of course I did not listen, and just bought some MTX Audio Thunger8000 T8.5 components, thinking that the MA Audio's are too weak/cheap for this setup. I'm taking my car back in later this week for the test and to install the MTX's, hoping that this does the trick.
Has anyone successfully upgraded the speaker setup on their 5 series w/out changing the Head Unit? I'm stuck now on this "expensive" Sound Crusade and would appreciate anyone who could let me know there is an eventual happy ending in sight!! Thanks.![Bang Head [?|] [?|]](/images/smilies/icon_smile_banghead.gif)
